This machine is starting to get me down, leaking pump so I changed the pump and cound not get it to pump out. On the insistance of the customer I have changed the pump yet again same problem will not pump out, drop the drain hose and water will drain! I am starting to think that the motor is going the wrong way or yet again I may be wrong and my age is getting to me. Can any one help?
Hi matey! Is the pump running? When you fitted the new pump did you notice a adaptor on the end of the motor shaft, its like a plastic sleeve
the motor shaft and pump drive are different sizes!!!
hope this helps?
yep, I did the same thing years ago. the old adaptor will be stuck in the old pump, its a top hat kind of thing. there is a part number for it somewhere.
