Whirlpool WIE 2N19 UK fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool WIE 2N19 UK fault
Viewing 15 posts - 1 through 15 (of 15 total)
  • #100745
    flanaganst
    I’ve a fault with my Whirlpool WIE 2B19 UK. ECO, 65deg and 55deg lights on and 50deg flashing, any ideas? I can’t seem to find a list of fault codes for the machine anywhere on line. The power button will not let me switch it on or off now, the program button next to it seems to turn it on and off now, odd?
    #482027
    when a fault occurs on these you have to switch off at the socket to reset
    try this and see what happens when you try to use it again
    flanaganst
    Thanks Dave, had already tried that, went straight back into fault condition as soon as I powered it back on
    #482029
    problem is with this machine is the fault codes listed done make sense because of the lights done match with the listing
    first thing to try is look for flooded base. most dishwashers have a float in the motor area that triggers a fault if water gets in there
    you need to access the base and see if there is water down there
    flanaganst
    Thanks Dave, not flooded, it will actually run the Eco cycle, won’t let me change to other cycles
    #482031
    think i would remove the control panel and look for signs of water ingress
    flanaganst
    Will take a look, thanks for the advice Dave
    #482033
    flanaganst
    Bone dry, no signs of any water damage. The module with the on/off button and program button must be fried. Power button not turning machine on and off. Program button turning machine on and off instead! But not allow me switch programs
    #482034
    does sound like that board is toast but the only way of finding out if your right is to swop it
    flanaganst
    My thoughts exactly, thanks Dave, can’t find any online, will try my local parts place after the Easter break. Thanks for the help.
    Steve
    #482036
    if you get me all the numbers of the label which includes commecial code and serial i will find you a part no
    flanaganst
    Thanks Dave, see below, I’ve spotted the part on a site or two but all saying ‘no longer available’ …never a good sign
    WIE 2B19 UK
    I.C. 769991002212
    S/N 451851032765
    #482038
    well i get it to be this one
    part no C00630930
    double check with them to be Certain
    Modulo Fi Ess 6p Amb Led 2b Gwh Al 2018 J00711460 – Hotpoint Spare Parts
    flanaganst
    That’s the one, you’re a legend, thank you, will let you know if it fixes my problem…. Searching by whirlpool I found nothing, should have been trying hotpoint 🙂
    #482040
    flanaganst
    Hi Dave,
    New part arrived and installed today and issue sorted. When removed is could see minor corrosion on board where power and program buttons join to board, looks like the buttons where shorting each other.
    Thanks for all the help.
    Steve
