Whirlpool wont spin
  • #37347
    kjmac1980
    Hi all,
    i’ve got a whirlpool AWO3551 which wont spin. The pump goes for about 10-15 seconds but then the start light,spin light,400 and the 100 light all flash and the display shows FO6. So far i’ve replaced the motor and doorlock but still no joy. I’m now thinking it could be the timer module but dont have a spare one to try. anyone had this before?
    thanks inn advance
    kevin
    #254490
    gegsy
    Re: Whirlpool wont spin
    Before spending anymore, its worth checking each pin from motor to module in turn for continuity, just in case its a poor connection or broken wire 😉
    Power off if you are to have a go :plug:
    kjmac1980
    cheers greg
    i’ll check the pins, the wires seemed fine (no breaks) but that was just a quick check.
    thanks again
    kevin
