Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Whirlpool(Bauknecht)Dishwasher GSF4872-drain pump won’t stop
- This topic has 9 replies, 4 voices, and was last updated 20 years, 3 months ago by
volvomec.
December 29, 2005 at 5:08 pm #14366
volvomec
Participantand therefore the programme cycle doesn’t move on…
There must be some sort of sensor that tells the dishwasher when it is
empty of water and can switch off the drain pump. I have checked
the diaphragm valve and it is ok. Could it be the “probe feeler” or
does any one else have any other suggestions ?Is there anywhere a service manual can be downloaded/bought on line ?
Thanks in advance, Mark…
December 29, 2005 at 6:51 pm #159167Penguin45
ParticipantRe: Whirlpool(Bauknecht)Dishwasher GSF4872-drain pump won’t
Undertray flooded, flood protection switch activated by polystyrene float. Drain undertray to reset switch, find the leak.
Power off if investigating, or click the link below for an engineer.
Penguin45.December 29, 2005 at 7:20 pm #159168volvomec
Checked the polystyerene float switch with a multimeter and it is OK. There is no leak and I have had the bottom off and no obviousl signs of any problem. Any other ideas ?
Thanks, Mark…
December 29, 2005 at 7:34 pm #159169Penguin45
Probably pump triac on computer board gone o/c in that case. Nasty – board is £140 from memory. P/no 4812 214 78136 should you wish to order – contact spares@ukwhitegoods.co.uk for confirmed prices and availability.
Penguin45.December 29, 2005 at 7:43 pm #159170volvomec
Thanks for your help – will check it out.
As a matter of interest, what is it that detects that the dishwasher is empty and that the pump should be swithed off – is it the diaphragm switch ?
What does the “feeler probe” do ?
Regards, Mark…December 29, 2005 at 7:48 pm #159171Penguin45
Diaphragm switch controls water level by air displacement, feeler probe is the NTC temperature sensor.
Penguin45.December 30, 2005 at 8:54 am #159172volvomec
OK so what is it that tells the dishwasher when it is empty and the drain pump can be stopped ?
Mark…
December 30, 2005 at 9:38 am #159173Dave_Conway
volvomec wrote:OK so what is it that tells the dishwasher when it is empty and the drain pump can be stopped ?
penguin45 wrote:Diaphragm switch controls water level by air displacement
December 30, 2005 at 3:54 pm #159174volvomec
It was the drain pump triac, but I managed to replace just the component and not the whole control board.
Thanks for your help, Mark…
February 5, 2006 at 5:34 pm #159175Dave C
Penguin – you is de man 😀
just found your ‘drain the tray’ post after 4wk of fretting.
Worked first time. Thanks mate :D:D:DTurned out to be the inlet pipe to the salt pot. Jubilee clip slid down and water filling the drip tray, should some poor unfortunate have to go through this again 🙂
D.C
