Re: Whirpool 6Th Sense – Short Program Takes Hours To Comple
various things can extend a programme but on most modern machines they come up with a fault code
no sure with the whirlpool off hand but I would check
1 time to fill since the machine fills about 4 times if it takes too long it adds time times 4
2 drain same reason
3 heater some machine like bosch and zanussi don’t give a fault code for failed heater just makes the programme longer while it waits for heat and then give up and finishes programme
check the programme you are using against the handbook time to see how far out it is
