Whirpool ADG7550 not draining-changed the pressure switch
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirpool ADG7550 not draining-changed the pressure switch
  • #72324
    quietlife
    My ADG7550 has stopped draining. If I start the wash cycle, it stops after a while and flashes four times which indicates drain issues. If I then put it on a rinse cycle , the pump will drain the water, so that works.
    I replaced the 3 tag pressure switch as searches on here suggested that was the likely problem, but still doing exactly the same thing.
    Any ideas or is it time to get the credit card out.
    Thanks in advance.
    #384200
    scientist
    Re: Whirpool ADG7550 not draining-changed the pressure switc
    Might need to check the connection block for bad contact on the diaphram switch. Have heard a few Whirlpool guys changing the block for spade connectors…! Maybe…
