Hi , The machine goes to the drain cycle when started, The main on off light is blinking and I have tried resting it for 30secs but wont work. The machine appears to be stuck in the drain cycle, If I pour water into it it empties thro outlet. Cannot seem to reset the electrics. The drain motor stops and restarts if I open close the door. Any ideas appreciated, mechanically it seems oK as it was working with no problems.
The base has flooded and safety float activated to stop machine from flooding. You need to investigate for leaks. Also count the number of flashes this is the fault code.
