whirpool adp5440
  • #30710
    fasetester
    hi guys what would the problum be with awhirpool dishwasher model adp 5440. start ligh flashes pre rince ligh lit when start button is held in just runs pump thanks fasetester. 🙂
    #228129
    gegsy
    Re: whirpool adp5440
    How many times does the start lamp flash?
    If the Start button is held in, it will cancel the programme and yes it will drain 😀
    fasetester
    thanks greg for your reply not sure how many flashes. would it help if the dishwasher was reset. how do you reset this dishwasher thanks. faseteter
    #228131
    gegsy
    gegsy wrote:If the Start button is held in, it will cancel the programme
    fasetester
    hi greg the fault was a flooded base 2 flashes of the start button. tiped it back then program worked ok. if it floods the base again what would be the most likely cause. thanks fasetester. 🙂
    #228133
    Connecting hose from circ pump outlet to sump is always a good one……
    fasetester
    Is that the circulating pump chris that if the hose leaks you have to change the washer pump is it an askroll pump and is there no way to repair it, its an expensive job for a hose leak. 😮 And does the IWMS leak on these dishwashers ❓ ❓ So far, So good. When i tiped the dishwasher back the program started ok. so it might have just been a one off, Hopefully anyway 😆 😆 😆
    Fasetester! 😀
    #228135
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159
    Yup, that motor.
    fasetester
    the dishwasher is playing up again its over 2 weeks. i thought it was fixed. if it is leaking it must be very little. to go for over 2 weeks any one have any pointers what to look for. can you get at this dishwasher from the front and if so how does the kick pannel come off. and does the sides come off all help welcome thanks fasetester 🙁
    #228137
    fasetester
    no one have any advise why it would go ok for over 2 weeks and then actavate the ant flood system. and does the front kick plate come off and the side pannels. i have to check it out in the morning thanks fasetester.
    #228138
    Surprisingly enough, all the panels are held on by screws, little Torx ones.
    Drag it out and observe.
    fasetester
    its not the pulling out that bothers me it how long it goes for before it faults. and does the kick panel come off and the sides bit stressed out at the min had a family brevement 😥
