Service no 854970615000
Need help with this one if anyone can help please, before I order a PCB.
Symptoms, over freezing showing -24. Try to change temperature settings and the thing goes berserk, relay chattering on and off.
I tried what I thought was re-set, switch off for a while, switch back on holding down fast freeze button. “C3” came up in display.
I can only surmise that the PCB and or thermistors are faulty, boards £100ish 😥 so I want to be sure that this is the fault. Are the thermistors foamed in?
My only worry is that the freezer is in a garage and the current cold ambient temp. is effecting it
