whirpool awod as 147
  • #84607
    HotDog
    this machine is coming up fo5 found wiring broke at ntc which is located behind the front balance weight it has two wires moulded into it when i try to order a replacment it comes up with the standard type that you would push the small ntc plug into it ,problem is i could make it fit but it sticks out to far so you cannot get the front weght back on any one help :rolls:
    #426242
    HotDog
    Re: whirpool awod as 147
    sorry it wa coming up service not f05
    #426243
    Allsorts
    Use the 85 code to order the part and you should get the right one
    #426244
    HotDog
    thanks will give it a try
