Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › whirpool awz 510 e programs not working
- This topic has 9 replies, 3 voices, and was last updated 11 years, 5 months ago by
slyp98.
November 7, 2014 at 11:16 am #82944
slyp98
ParticipantHi guys this machine wont do ant other programs but wash it wont spin it wont drain wont dry looks like pcb trouble anyone have any info cheers 857594115000
November 7, 2014 at 11:42 am #421224electrofix
ModeratorRe: whirpool awz 510 e programs not working
info is a bit confusing
in post you say it wont do any other programmes which sounds like it does some. if so which ?
if it wont go at all then my first look would be heater, brushes and door lock
November 7, 2014 at 2:19 pm #421225slyp98
ParticipantRe: whirpool awz 510 e programs not working
Sorry for confusion , machine starts on all programs with the same result, so on a 50 degrees cotton cycle is the same as a drain and spin cycle and a drying cycle ie: the door locks runs pump for 10 seconds fills with water and starts tumbling, the same for every program on the dial hope that clears it up Kieran
November 7, 2014 at 2:59 pm #421226electrofix
so 50 degree wash
pump runs, then fills (all the way or just a bit?)
it then tumbles but does it heat ?does sound a bit like a timer prob. have been looking for a picture of the panel but cant find one
dave
November 7, 2014 at 4:03 pm #421227slyp98
Yeah its heating water also , it doesn’t look like its full now that you say it but its covering the paddle if the paddle is at the 6 o clock position
November 7, 2014 at 4:54 pm #421228electrofix
out of ideas now assume it gets to rinse and wont pump out or spin.
have also assumed you have checked for blockages in outlet and sump hose etc and for a failing pump (have you checked to see if the pump coil is overheating some have cut outs ?)
when its empty does it spin then
November 7, 2014 at 5:26 pm #421229Grendal
Its a merloni machine so if you have checked for earth leakage on the heaters and motor and they are OK I would suggest the module
November 7, 2014 at 5:37 pm #421230slyp98
It wont go into spin , just keeps on going like its stuck on one program takes water tumbles washes same sequence no matter what program is selected i didn’t check pump or motor as they are both working , megger showed no leakage (pat) dunno what to do i guess ill just check all components one by one anyone have motor values
November 7, 2014 at 6:24 pm #421231electrofix
let me get this right
you are saying that no matter where you put the programmer knob it does the same thing
if so may be the programmer switch connect lists it as 5045175606607
litle red switch with a blue stem
am assuming its the programme switch but all its descibed as is selector switchdave
November 7, 2014 at 8:18 pm #421232slyp98
Yes that’s what’s happening could be the selector i spose but why would it turn off in off position , i suspect if it was the selector switch it would bo stuck on one program and not turn off ?
