WHIRPOOL DISHWASHER ADP 4504
Home Forums Public Support Forums Help And Support Dishwasher Help Forum WHIRPOOL DISHWASHER ADP 4504
  • #38970
    GORDONPN
    I have had a Whirlpool ADP 4504 Dishwasher which has worked well for about 4 years. However I moved it while having the kitchen re vamped and when I put it back it faulted.
    The machine fills ok but then the start light flashes 11 times then pauses then repeats this sequence continually.
    Any advice would be appreciated.
    #260521
    Re: WHIRPOOL DISHWASHER ADP 4504
    Optical Water Indicator failure. Interesting, it isn’t fitted to your machine….
    Have a look in the sump at the 3 o’clock position – there is a black grid, which is the Water level Indicator. It has a bad habit of filling up with congealed fat and jamming. Hot water and a toothbrush may clear it, if it doesn’t, remove the device for better access and cleaning. It’s a twist fit from underneath.
    Power off, first.
    GORDONPN
    Penguin45 wrote:Optical Water Indicator failure. Interesting, it isn’t fitted to your machine….
    Power off, first.
    Thanks for the advice. I cleaned up the black grid and the dishwasher is now up and running
    Pete
