Whirpool oven won’t work.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Whirpool oven won’t work.
  • #92810
    PM122
    Model number AKZ451/X/01 858545115070 Type FCSM6.
    Hello,
    I’ve got the above whirlpool built in oven. It was working fine last week, but when I came to use it this week it won’t heat up. When I try to use the oven, the fan kicks in but it doesn’t heat up. Grill and cooker top work fine. I’ve tried switching it off at the mains and re-setting the clock, but to no avail.
    Please help.
    #452265
    Re: Whirpool oven won’t work.
    first thing to check is the element. if its failed it will act exactly like your symptoms
    but there are other things that can cause this although the element is most liklely
    PM122
    Thank you. Howe do I check the element?
    #452267
    this is where it get technical
    to check it you need a multimeter to check if its open circuit (broken)
    or change it and hope for the best
    PM122
    Ok, thanks for that. Looks like I’ll have to book an engineer 🙁
