Model AWM5125/5..12nc 857051215592.
Set it to prog 4 60° wash. Fills, tumbles perfectly but timer advances at least two impulses in no time at all. Stays around prog 6 for about 5 or 6 minutes then advances to just before the ‘Daily Wash’ symbol. Drains out then stops dead.
Switch it off then back on with the On/Off button and you can hear a faint noise from the timer and it fills for a second then cuts out again. Repeat this process of switching off/on for 7 or 8 times and then it continues to fill normally and completes the rest of the cycle. 😕
Does this sound like a control unit fault?
