Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › White Knight 44AW (031244A15003) T/D Replacement Heating Element Chafing on Drum
- This topic has 7 replies, 3 voices, and was last updated 5 years, 4 months ago by
jontymox.
November 14, 2020 at 4:11 pm #98645
jontymox
ParticipantGood afternoon all,
Another obscure problem to report!
I’ve replaced the faulty heating element with an Electruepart pattern element.
However, having carefully reassembled the above, I’m sure the subsequent chafing, and accompanying noise is due to the element… i.e. particularly the inner section, which I think protrudes a little prouder than the original. (although the original was discarded last week!)
The genuine part appears to be obsolete, as Crosslee/White Knight have ceased trading, and re-positioning/bending/modifying the replacement element isn’t feasible.
I’ve ordered another Electruepart element, but would be grateful if anyone else has experienced the above or similar, and could advise…
Many thanks,jonty
November 14, 2020 at 4:22 pm #473167jontymox
Participantp.s by the inner section of the element, I particularly mean the “neck area” where the item is bent away from the bracket to form its circular shape. I didn’t mention, but I can see where the drum has been chafing that particular area of the element.
November 14, 2020 at 8:47 pm #473168electrofix
Moderatorlast time that happened to me i had the clips on wrong
have used non gen qualtex one for years and had no problems
November 14, 2020 at 9:02 pm #473169rolf
ParticipantI’ve had exactly same problem with non geuine in the past. It seems to of been a few years since I last did one so can’t remember the supplier. I’m sure it was something to do with the bracket in a slightly different place. I do remember genuine one sorted it. Pain in the arse to change.
November 14, 2020 at 9:06 pm #473170rolf
ParticipantYou can buy the kit with stats the whole 9 yards for about £20.
November 15, 2020 at 9:27 am #473171jontymox
ParticipantThanks all,
Do you know where I can obtain the above kit?
November 15, 2020 at 1:02 pm #473172jontymox
ParticipantHopefully sorted now by “modifying” element shape, and re-aligning!
Won’t know for sure until return to customer’s, as backplate, element etc is at my workshop…
November 15, 2020 at 3:24 pm #473173rolf
ParticipantIf you do have trouble Amazon have got the genuine kit. £23. Can’t find it on conect or maddocks.
