White Knight 44aw Not Getting Hot.
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum White Knight 44aw Not Getting Hot.
  • #83609
    pmac
    Hi All
    I have got a White Knight 44aw drier, that I have had for about 4 years, it has been brilliant up until now, except this weekend it has been struggling to dry clothes. When I investigated it only seems to get luke warm instead of hot like normal. The hi / low heat switch seems to operate ok, but makes no difference to the internal heat of the machine. I suspect the element has gone, is it a dual element for the 2 heat settings? I have no issue stripping the machine down, but if it is likely to be the element I would rather buy one first before I strip it down. Finally would you recommend getting a genuine element or would a pattern one be ok?
    Any advice greatly recieved.
    Many thanks Paul.
    #423258
    bazza500
    Re: White Knight 44aw Not Getting Hot.
    The 44aw does have a dual element. I have found little difference between the genuine ones or the pattern spare .
    #423259
    pmac
    That’s great, thanks for the reply, I will give a pattern element a go, and see how I get on.
    Many thanks Paul
