White Knight 767C T/D
  • #43389
    spanner51
    Called to this condenser dryer which was making a vibrating noise. The noise was caused by a small rubber bellows seal behind the rear fan, on the motor shaft. I put a small dab of grease on it, which cured it. (for the moment)
    Would it be better to replace it, or remove it? (what cr@p design). Any suggestions apprieciated.
    #277091
    Re: White Knight 767C T/D
    I had to completely dismantle that model the other day to fit a new front fan. There was no such bellows on the one I did just a felt shield around the shaft :?. It seemed to work fine after the repair.
    Mike.
    #277092
    funkyboogy
    havent came across this myself,
    had plenty rear fans coming loose
    ally
    #277093
    DentedPorsche
    Hiya,
    No bellows on mine, just the felt pad in the shape of a cross.
    Brian 😀
    #277094
    jackster
    The felt bellow was supercided by the rubber one and they are crap. Dont remove it though or it will cause the bottleswitch to warp at the top. I have had a load of these seals coming off or spliting allowing steam to escape up the back and melt the switch, I always re-fit the old felt type seal when replacing bottle switch.
