white knight 77aw condenser dryer
Home Forums General Trade Forum white knight 77aw condenser dryer
  • #71868
    delta01
    hi this machine is causing condensation on walls, it is in a small pantry sized room, i have not come across this before any suggestions appreciated thanks
    john
    #382621
    tomdave
    Re: white knight 77aw condenser dryer
    check front fan blade might be blocked or spinning on shaft regards david.
    #382622
    bw
    Check the machine seals. Machine leaks in small unheated rooms will cause condensation on walls.
    #382623
    delta01
    thanks BW this machine is not v old, i looked at door seal it seems ok, customer did mention she saw steam coming from that area though, i had gone to look at washer so did not have time for a thorough investigation,
    will need to have another look at it thanks
    John
    #382624
    stratfordgirl
    Are the condenser, air intake and ducts clean? Is there enough ventilation in the room? It’s surprising how many people don’t realise condenser dryers don’t work efficiently in an enclosed space.
    #382625
    delta01
    thanks stratforgirl i checked for usual blockages,and think the customer said she opened a window when in use, i am calling back today to investigate
    john
