White Knight 77AW condensing dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries White Knight 77AW condensing dryer
  • #70859
    twicknix
    Got a fault with no heat but everything works.
    Checked heater – ok
    Stats – ok
    Switches – ok
    Pump – can’t get to it but seems to work
    Motor – works
    Insulation reading of 37 mohms
    Wondering if the timer the culprit?
    #379220
    Re: White Knight 77AW condensing dryer
    you say you have checked stats but you also say you cant get at pump
    does this mean you have not checked exhaust stat ?
    twicknix
    I did not get to the pump, but I can say that the pump is working.
    No I have not checked the exhaust stats. It’s condensing so would they have exhaust stats? If so, where would I find it and how to get there?
    #379222
    they are at the front same as non condensor attached to the filter housing.
    got to take the rear off to get at and that normally means breaking the hot air fan unless your lucky
    twicknix
    Ok thanks mate. The hot air fan is easy to remove so no worries there. Will let you know how I got on.
    #379224
    twicknix
    Turns out that it was the inlet thermostat. Don’t know how I missed it as I was sure I checked it, after all a second visit made it worthwhile.
    #379225
    know that feeling you could kick yourself for missing it first time
    glad you found it
