White Knight 85AW Front Bearing Pad
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum White Knight 85AW Front Bearing Pad
  • #84010
    Newbie1111
    I’ve just replaced the rear drum bearing. I had propped the drum but clearly there was some play and while fitting the new bearing I heard something fall. I have found a loose plastic widget under the drum. I’m pretty certain this is one of the two Short Front Bearing Pads part number 4213 077 40952 – it seems to match a part in a photo of the (Seal and Pads) replacement kit .
    My question – how do I refit? Must I remove the drum etc or can I get access by removing the front panel? Can anyone offer a running order for stripping down?
    White Knight 85AW 0312 85A 15000
    Type 84A
    #424502
    Re: White Knight 85AW Front Bearing Pad
    Remove the drum
    #424503
    Newbie1111
    Thank you Martin. Job done. Should have replied sooner but have been under the weather.
