I have a white knight sensordry (CL 447 WV) that has started knocking. I removed back and found that the central rear bearing rivets are loose through wear to the rivet hole (hole roughly double in size). Presumably this has been caused by wear to the bearing itself.
So, is this worth fitting a replacement bearing (using a kit?) with this kind of wear?
