cust says c/d not filling resevoir.its true…loads of water in the bottom.. feed tubes clear so i’m looking at either a blocked pump or a failed one.
how do i get to the punp? front off, pump by main motor, hardly any access in space between tub and cowling. so i thought back off…couldn’t get air distribution fan off! 😳
advice please
richard
lots of info on this one;
Someone told me to take the screw out the fan, spray your fav light oil, heat with hairdryer 5 mins, then ease from both sides. Worked twice so far.
Fan off, back off, lots of screws, disconnect heater, tub out.
Not as bad as it sounds.
Graeme
graeme, thanks will wait till wife goes to work and get the hair dryer. will i need to refit the front to give the bag of s### some regitity? 8)
richard
