White Knight C3A Compact tumble dryer fan blade removal
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries White Knight C3A Compact tumble dryer fan blade removal
  • #82794
    whiskeyjack6058
    Hi can anyone help me with this please? I have been out to a White Knight C3A tumble dryer and the fan blade has broken free from the steel column that fixes to the motor shaft. Question is, how does the steel column come off the motor shaft? My guess is it’s a screw threaded fixing. If so, what direction? I removed the pressed clip from inside the column but the fan doesn’t want to budge.
    Thanks in advance.
    Rob.
    #420827
    Re: White Knight C3A Compact tumble dryer fan blade removal
    all screw on fan come off in the direction of rotation
    if it spins clockwise it unscrews clockwise
    lee8
    Stops them unscrewing themselves.
    #420829
    no i am back in work
    try here
    http://www.whiteknightrange.co.uk/white … ad-SM.html
    may be more info
