White Knight C77AW
  • #91057
    wchuk74
    I have the above condenser dryer, all is well apart from a very stiff Dial. You can just press start and away it goes, but if you want to change timer, you can’t.
    Any advice please.
    Regards
    Wayne
    #446893
    captaincaveman1
    Re: White Knight C77AW
    Could just be a sticky build up behind the timer knob which should just pull straight off towards you .Removing the knob also expose’s the two securing screw’s for the timer should you need to replace it.
    #446894
    wchuk74
    Brill, thank u I’ll have a go at taking knob off later and cleaning
    Cheers
