Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › White Knight CL 847 not drying properly.
- This topic has 9 replies, 3 voices, and was last updated 13 years, 1 month ago by
gurrg.
February 10, 2013 at 11:28 pm #74071
gurrg
ParticipantHi. We have a White Knight CL 847 ‘A’ class tumble dryer, which has never seemed to work very well, even when new. The problem is that the dryer does not heat up properly, and the clothes will often still be wet after nearly two hours. Warm air does eventually appear at the out vent after a few minutes, but it isn’t very warm, and seems to turn cold at random for long periods. I’m guessing it’s a thermostat or heating element problem, but which is more likely?
Thanks, Greg
February 11, 2013 at 6:51 am #389843neilsukwg
ParticipantRe: White Knight CL 847 not drying properly.
First check you have selected full heat on the front selector switch…
Also check on the back of the machine, you will find (if one is fitted to this model) a red button.
When you press it you will either get an audible click (meaning that you have reset the thermostat) or no click meaning that the fault lies else where and you need a qualified engineer which you will find on this site.
February 11, 2013 at 7:26 pm #389844gurrg
Hi. We’ve had it for a few years, and have tried all combinations of the heat settings. The reset button didn’t click. I’ve now checked continuity of both heating elements with a multimeter, and they are ok. I’ve also checked that power is reaching both elements, and it is. The high/low heat switch is also working correctly. I’m beginning to think that this dryer is simply not up to the job. We keep it in an outhouse, and this is obviously very cold at this time of year. I have also read today that this dryer can take up to seven hours to dry a full load!! Any comments or help appreciated, thanks.
February 11, 2013 at 7:49 pm #389845Martin
The t/stat that is located inside the heat shield has failed. You need to take the heater/back panel off to access.
February 12, 2013 at 1:23 am #389846gurrg
Thanks Martin. I’ll check that out.
Cheers, Greg
February 14, 2013 at 12:59 am #389847gurrg
Hi all. Before I stripped this machine down further, I checked the heater voltages through a complete timed cycle. On this machine, this takes around half an hour. The compete timed cycle consists of four separate spins of around five minutes each, separated by short anti crease reverse spins. The heaters are not powered for the anti crease spins. The power is applied to the heaters during the four main spins as follows:
1 Heat on for around 4 mins
Heat off for around 1.45 mins.Stop/Reverse
2 Same as above.
Stop/Reverse
3 Heat on for about 2.50 mins.
Heat off for around 2.44 minsStop/Reverse
4 No heat at all for around five minutes.
(This last one is presumably the cooling cycle.)
Does this seem reasonably normal for this machine? Grateful for opinions or suggestions.
Thanks, Greg.
February 14, 2013 at 8:06 am #389848Martin
Yep…sounds about right!
February 14, 2013 at 9:32 am #389849gurrg
Ahh…That’s what I was afraid of! Thanks for confirming that Martin. So it’s not actually faulty, it just doesn’t work too well kept in the outhouse this time of year. Mind you, neither would I, to be honest!
Thanks again, Greg.
February 14, 2013 at 10:43 am #389850Martin
I’d still take the element out and check that thermostat clamped to the back panel. Better still replace it as they fail often….!
February 14, 2013 at 2:28 pm #389851gurrg
Ok, I’ll try that then. Cheers.
