White Knight CL247WV Keeps cutting out.
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum White Knight CL247WV Keeps cutting out.
  • #67593
    P192
    Symptoms:
    If I run dryer on high heat setting it runs for 3 mins approx and cuts out. Wait a few mins and restarts ok from start button.
    Continue on high heat and times get shorter before cut out, and longer for cool down?
    On low heat it will run empty for 7-10 mins then cut out, but loaded with damp towels runs ok.
    Parts replaced;
    Inlet Thermostat. Manual TOC.
    Checked Exhaust Thermostat. Close in normal,open when dipped in cup of tea! closes again when blown over. Cant verify temp opens closes though.
    Other points noted. When its running drum squeaks intermittently and appears to stutter prior to cutting out completely. ( like an engine running out of fuel.
    Could Ex- Thermo be operating early (less 60 deg).
    Please help, Wife’s wagging finger at me :eeek:
    #367899
    gandh1
    Re: White Knight CL247WV Keeps cutting out.
    can you please verify cl247wv is the correct model?
    if its vented, id be checking vent hose for fluff clogging and that hose isnt bent over or drooping below the height of wall hole…
    #367900
    P192
    Hi Gandh1.
    Thanks for the reply. I can confirm its Cl247WV. I’ve taken Vent hose off and cleaned it from the fan to exit. I’m also running it on low heat setting just now as it’s ok up to a point. That’s leading me to think it IS the exhaust Thermostat as its the one controlling the elements. When the clothes are in it is slowing the rate the Ex- Thermo is reaching its cut off point. However I’ve ordered one as its the last device controlling temp? Probably been cheaper buying a new dryer. lol.
    #367901
    P192
    BIG problems.
    Replaced Inlet and exhaust thermostats. Replaced manual Thermal cut out. Still shutting down on high heat setting after a few mins. Low heat works fine with no problems.
    #367902
    gandh1
    p192, i have tried both of my main spares distributors and neither recognise that model number not even google does!
    Not sure if anyone on here using master part could say whether its on their system. Cant really help or cross check if the parts you have are correct im afraid…
    Without being able to find info on the model, i cant tell you if it has other certain parts on it! However, you say it cuts out totally, iirc with w/k’s when one of the stats fail it will just stop the heating circuit, not the motor drive as well. Also i just noticed you says it stutters, w/k are known for the plastic fans to wear where they use a pin to secure them to the shaft, this could easily cause a stuttering sound, as the inertia kicks in when the motor stops to reverse its action, and obviously if its worn so bad, it will not be able to move the amount of air necessary to stop it cutting out.
    can you take a picture of the sticky label on the rear for us please?
    #367903
    P192
    Hi.
    Thanks gandh1, sorry wrong model details. Thought Cl427WV was model number, its type. here is details of dryer.
    Make White Knight,
    Model CL427WV
    Model number 0312 427 15007/22
    same unit here, http://www.pricerunner.co.uk/pl/17-2152 … are-Prices.
    thanks.
    #367904
    gandh1
    yep, defo check the fan, and check the capacitor. otherwise if its completely cutting out its the motor or timer…
    #367905
    knight4U
    http://www.whiteknightrange.co.uk/downl … &_variants
    #367906
    don
    knight4U
    What is the point of this post in an old thread?
    I have removed part of the link so it does not open. White Knight will have a copyright on this sort of information and by posting it in the public domain we could be in breach of copyright if we leave it be.
    Don
    #367907
    knight4U
    Mod edit: What is the point of this post in an old thread?
    Don
    Point “INFOMATION” – age of thread irelavent to anyone trying to find info on CL247WV
    For those who may care to know White Knight are part of the CROSSLEE PLC group and the link for :- DOWNLOADS
    User Manuals
    Service Manuels
    WIRING diagrams
    can also be found on their page – crosslee.co.uk
    Just trying to help TY.
    #367908
    don
    The last post on the thread was 18 months ago so either the OP repaired or had it repaired or has by now replaced it by now.
    The Crosslee link is fine if the public wish to download direct from their site for their own use, it’s the sharing part in a public domain I was trying to protect.
    Fair shout though 🙂
    Don
