White Knight CL411 Tumble Dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum White Knight CL411 Tumble Dryer
  • #27447
    JohnGilbert
    This dryer has started to either not turn or to only turn one way ie does not reverse. ocassionaly it works corectly. Any sugestions re fault tracing would be appreciated.
    Regards
    John Gilbert
    #214074
    Re: White Knight CL411 Tumble Dryer
    If it hums when it doesn’t start, it’ll need a motor start/run capacitor. If it doesn’t hum, or the stop/start/reverse sequence is rather random, it’s probably the timer.
    Power off if you’re going in……
    JohnGilbert
    I have now replaced the timer with a new one from UK White Goods, but the problem persists, it only rotates one way except very occastionally it briefly reverses direction.
    #214076
    You haven’t said wether or not you replaced the motor capacitor before you fitted a timer, which is what Penguin45 actually suggested.
    JohnGilbert
    No I have not because it does not stop and hum it just keeps going one way
