White Knight CL412W Tumble Dryer
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum White Knight CL412W Tumble Dryer
  • #97077
    thewelder
    We have an old White Knight CL412 W Dryer Sensordry dual heat Tumble Dryer, which works intermittently the reset button is being used more often, but even that dosen’t seem to work as well now. I have to turn it off and on flick the setting button bang it shake etc, then the heater will work and dry as normal
    which leads me to think it isn’t the element, any ideas before i scrap it.
    Chris
    #466006
    if your having to push the reset button all the time then you probably got an air flow problem. if there is not enough air flow running over the element it over heats and trips the stat
    thewelder
    electrofix wrote:if your having to push the reset button all the time then you probably got an air flow problem. if there is not enough air flow running over the element it over heats and trips the stat
    Thanks for the reply, is there an easy way to resolve that problem?
    Chris
    #466008
    you need to check the vent hose and make sure that its not blocked and you have a good air flow
    has it been making any odd noises ?
    thewelder
    No odd noises at all, works great when i can get it working, maybe the wife is overloading it at times i think that could be an issue, might wait for a nice day and strip it down see if anything is blocked
    Chris
    #466010
    really easy to strip after laying unit on its front. Disconnect wires at top left from stopping the back coming off but take good photos before you do
    drop the motor out and check the fan
