Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › White Knight CL447 dryer Push start!
- This topic has 15 replies, 4 voices, and was last updated 20 years, 10 months ago by
admin.
May 21, 2005 at 7:07 pm #9711
KeymasterI have a white knight wk447 reverse action dryer.
When its switched on i am getting power to all components but the drum won’t rotate.
Give the drum a little push and it starts, until the reversing action tries to kicks in and it tries to change direction.
I have a feeling its the capacitor on the motor but what does everyone else think?May 21, 2005 at 8:27 pm #135397Penguin45
ParticipantRe: White Knight CL447 dryer Push start!
Diagnosis is correct, you want one of these:
http://www.ukwhitegoods.co.uk/modules.p … ucts_id=94
All readers be advised that push starting the motor isnot a safe procedure – fingers have been lost over the years.
Penguin45.May 21, 2005 at 8:41 pm #135398Dave_Conway
bob fm lincoln wrote:I have a feeling its the capacitor on the motor but what does everyone else think?
Spot on 😉
Check the uf value and you’ll find one here:
http://www.ukwhitegoods.co.uk/modules.p … Path=58_91
Power off before replacing of course :plug:
May 21, 2005 at 8:42 pm #135399Dave_Conway
8)
May 21, 2005 at 8:52 pm #135400Penguin45
:wave:
May 21, 2005 at 8:57 pm #135401admin
KeymasterRe: White Knight CL447 dryer Push start!
Thanks for the help!
June 5, 2005 at 9:27 am #135402admin
Just about to go to the store to buy a new dryer and just thought I would check t’internet first. I have exactly the same problem with my model so I have ordered the capacitor and hope this will cure it,
thanks
June 5, 2005 at 7:21 pm #135403Dave_Conway
Come back and tell us if it works please 😀
June 6, 2005 at 8:45 pm #135404admin
Well thanks to this forum I have saved my White Knight 447 WV from certain destruction at the tip !!! I was just going to go and buy a new dryer as I thought this one had dried its last.It had all the symptoms of the first post……push start……(I know very dangerous !!!)etc….so after reading this post I thought I would go and buy a capacitor…hey what did I have to loose…I was ready to buy an new dryer !!.Put the capacitor in tnite and its working again.Thanks to all who post advice.
Paul.
June 18, 2005 at 3:58 pm #135405admin
I have exactly the same problem with my white knight cl767 tumble dryer. How do i find out what capacitor i need (i can’t seem to find the manual that would have come with the machine), and how easy is it to fit for a novice? Do i have to take the motor out, where is the capacitor located in the machine?
June 18, 2005 at 5:30 pm #135406Penguin45
Is what you require. The capacitor may be accessed through the lower rear panel of the dryer – with the power off of course :plug: .
Penguin45.June 19, 2005 at 9:38 am #135407admin
I am still trying to find the capacitor. I’ve taken off the back panel, and now trying to take off the lower panel, but there is a white round vent (i think this is what it is) on the bottom left hand side, and i’ve taken the screw out but it does not pull off. Don’t want to force it off in case i break it. I can’t get the lower panel off, unless i get this white round vent off. Am i looking in the right place?
June 19, 2005 at 9:53 am #135408Simon46
The lower panel is the only one that needs to come off. Capacitor is in the vicinity of the motor. Unplug first.
Simon
June 19, 2005 at 10:06 am #135409admin
Thanks for the info. But, i’m still confused. What about this white round vent, i cant get the lower panel of unless this comes out, and although i’ve taken the screw out, it won’t come off. Should it just pull out, or am i looking in the wrong place.
Thanks for any help
June 19, 2005 at 10:48 am #135410Penguin45
Hold on chaps, this isn’t the 447 at the top of the thread, it’s a 767 which is a condenser………
Sorry Steve – bit of a mis-understanding. This one is a total demolition job to access the motor. The entire back panel, fan, heater and drum has to come out from memory and it is a complete sod of a job, even for us professionals. If you’re not feeling confident, I’d stop now and get some pro help.
Check Directories or Repairs@ for a UKW repairer in your area.
Apologies and regards,
Penguin45. -
