White Knight CL767c No heat
Viewing 15 posts - 1 through 15 (of 17 total)
  • #25011
    Twoten
    I looked at a White Knight last as a last call.
    Customer complained the element only seems to work on low heat when high heat is selected and no heat when low is selected.
    The element and both of the rear stats test out OK. I suspect the problem is the exhaust stat but the machine was in a tiny shed full of clutter, dark with a security light flashing on and off outside. I had had enough, it almost ended up at the bottom of the garden. I decided to call it a day before I lost my temper.
    What is the best way to get to the exhaust stat on this machine? I had a quick look and assume it’s the fascia off then the front panel complete with front duct. As I couldn’t lay the machine down and it was getting late I didn’t explore much further. Again as this appears to intermittent there is a good chance I will get to the stat and it will test out OK.
    Also has anyone got a wiring diagram for this machine?
    #204215
    VillageIdiot2
    Blocked
    Re: White Knight CL767c No heat
    Would it be the exhaust stat if it heats on low…… 😕
    #204216
    DentedPorsche
    Open circuit exhaust stat would kill all heat.
    If I remember correctly the high/low heat switch switches half the heater on and off so I’d suspect a wiring problem or a fault on one half of the heater.
    Brian
    #204217
    Twoten
    washdoctor wrote:Would it be the exhaust stat if it heats on low…… 😕
    The customer said it heats on low, when I checked it heated for a few minutes then It wouldn’t heat on either setting.
    #204218
    Twoten
    Can anyone tell me the best way to get to the exhaust thermostat on this machine?
    #204219
    According to the drawing it is locate at the base of the front ducting. No idea how you access it though, sorry? 🙁
    #204220
    cab
    DRUM OUT JOB!
    CAB
    #204221
    Alanj
    Twoten,
    is it possible to remove lower plate at rear of dryer to gain access?
    Alan
    #204222
    Twoten
    Alanj wrote:Twoten,
    Alan
    I tried to get access this way releasing the screws at the bottom of the front panel but I couldn’t reach up to the stat to test or remove it.
    #204223
    scots
    Only way in is from rear, drum out.. The real problem is getting the plastic fan off. Its a helluva machine to work on and thats with lots of room.
    I changed one of these stats a couple of weeks back for o/heat problem, wish I’d never started!!!
    Brian
    #204224
    Twoten
    Oh………..I can’t wait
    #204225
    MC
    its the timer that needs changing
    #204226
    Got very much same problem as Twoten with one of these. Totally blocked into a miserable cupboard/alcove behind a washer and a big f/freezer which would have to be taken out (and put where?) before I could get enough space to do any serious dismantling.
    Problem is that m/c doesn’t seem to get high heat according to customer.
    Now, interestingly, the element measures 15ohms through one half and 45ohms through other half. Does anyone know if that is right? I had expected it to be half and half but maybe I’m wrong. It looks/feels intact.
    Incidentally, I’ve already replaced the cycling stat and the safety stat over the heater and when I crushed the old ones I thought I had it as the cycling stat contacts were quite well burnt. Have checked low heat switch and that measures OK. Maybe I should look at timer?
    TIA.
    Mike.
    #204227
    How badly restricted is the airflow, Mike? If it really is stuffed into a corner it may be as simple as that.
    Penguin45 wrote:How badly restricted is the airflow, Mike? If it really is stuffed into a corner it may be as simple as that.
    Didn’t think of that. But I’m pretty sure the thing ‘s been in there for a good while, presumably functioning normally. There’s no junk around it. I might have exaggerated how tight the space is. I managed to turn it sideways to get the back heater cover off.
    See you haven’t broken your habit of staying up late!
    Mike.
