White Knight CL847 – Works for 45 seconds and then stops
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum White Knight CL847 – Works for 45 seconds and then stops
Viewing 1 post (of 1 total)
  • #72329
    Teamwild
    I have a CL847 tumble drier that was generating a nasty squeak and I put this down to a worn belt which I have replaced. Other than the noise the drier was working fine.
    Since I changed the belt, the drier switches on and turns for 45 seconds before pausing but then fails to continue.
    Correct me if I’m wrong, but if the thermal cut-out had tripped (I have made sure I pushed the red button) then the drier would not turn at all.
    Could you provide me with any ideas of what the problem could be and how I can verify it. I don’t want to be shelling out for parts only to find the problem still exists.
    Cheers.
