White knight CL93 dead
  • #63063
    allan73
    The above is doing nothing.I have a live feed into the module via the microswitch behind the bottle and door switch.I suspect module (no dry joints I can see) but I wonder if it could have lost a neutral somewhere lower down maybe a float switch?
    Can anyone advise on this before I order a module from Crosslee ?
    Allan.
    #352391
    gandh1
    Re: White knight CL93 dead
    w/k t/d + caps are a favourite spare… a connect plastic 8uf iirc will serve as an adequate test spare…
    #352392
    allan73
    Thanks for the reply Gandh1.This M/c is completely dead no heat,no motor,no pump nothing could a cap fault cause this ?
    #352393
    gandh1
    ill get back to you on that one, only ever had to fit bearing kits/rear fans/caps and obligatory new doors to w.k’s
    not sure whether they heat up if the motor isnt running because of the heat build up that would cook the stats if it wasnt at lest circulating?
    besides, irrespectively, always have a test 4uf, 7uf and 8uf caps on board as there only about a quid trade.
    #352394
    allan73
    Update,
    Module from Crosslee solved this,I think there was a duff relay on there. 8)
    Allan.
