Re: White Knight (Crosslee) 77AW condenser dryer bearing hel
i got the assembly off in the end, although you dont need to remove the spider to remove the bearing, theres a screw through the middle to hold the bearing to the drum spider! anyhow, the hole in the drum spider is goosed, runnning it with a s*****d bearing has opened the hole right up, so i now need a new drum ETC!
anyhow, there just short of £70 from crosslee (white knight) direct, so i gave layed it on the machine is only 2 years old, and i wouldnt expect a simple bearing to destroy the drum ETC ETC. so as a gesture of goodwill, they knocked me some money off! £47 delivered.. RESULT! thanksyou crosslee! Im well happy at your super customer service 🙂
B..
