I have a gas drier less than 2 years old that will not ignite the burner unless I get on my hands and knees and blow into the heat chamber which then let’s the burner light up, doesn’t need it every time but is annoying, simple blow at the burner and it’s away, it’s as if the mouse wheel extract fan is not spinning fast enough to draw the air through. Any suggestions would be much appreciated, thanks James
