Hello,
I have a White Knight CL38AW 3Kg Dryer, it has stared to make a screehing noise when it is working, I brought some new bearing pads for the front & rear of the drum, are they easy to fit? is it just a matter of un-cliping and removing the old ones, or do you have to strip the dryer down to get at them?
Thanks 🙂
You have to remove the heater cover and rear fan then undo the back panel. What’s most likely happened is the drum has worn into the back assy normally requiring both the back assy and drum to be replaced.
