Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › White knight small dryer CL372.
- This topic has 7 replies, 4 voices, and was last updated 15 years, 9 months ago by
megawatt.
June 18, 2010 at 8:02 pm #55331
megawatt
ParticipantGot to do a belt change on one of these. How do you get the fan off ????
Mike.June 20, 2010 at 8:06 pm #323298keithwilliams
ParticipantRe: White knight small dryer CL372.
its a right awkward job. but word to wise the belt has probably snapped due to the drum rear support ring having worn away and collapsed. i’ve been to quite a few like that. when ever ive changed a belt i’ve done it without taking off the fan and passing it under the motor after loosening it.
June 20, 2010 at 9:03 pm #323299megawatt
Yes Keith you are correct. Thanks for your advice.
Mike.June 21, 2010 at 6:50 pm #323300bigchrisoioi
easy get the fan off…..bend 5-6 of the blades away and get your mole grips on the shaft ……then twist the fan as it is screwed on a thread…as it unscrews the clip pings off…….you then continue to unscrew fan……on refitting rescrew the fan on and push the clip on with a nutspinner or box spanner….hope this helps
normally the rear bearing felt collapses and you have to change the rear panel, belt and drum…….nightmare little devils these!
June 22, 2010 at 8:54 pm #323301megawatt
Thanks Bigchris. The back looks ok so I have ordered the parts. Fan is yet still on waiting my attention.
Mike.June 23, 2010 at 7:07 pm #323302keithwilliams
so its screwed on is it? now i feel like a right numpty. i make no wonder i couldnt pull them off. thanks
June 23, 2010 at 7:35 pm #323303allan73
Are the fans left hand thread Chris ?
June 24, 2010 at 5:32 pm #323304megawatt
Looks like their was no need to take the fan off. I got the drum out and did the job with it on. The other option is to unscrew the motor and take it out with the back.
Thanks,
Mike. -
