white knight t/d
  • #28145
    hilly
    condenser dryer mod no cl767 i went to this machine about two weeks ago it was tripping rcd i removed back and found water in the back nr the fan so i asumed the pump wasnt draining and the water was building up and spraying onto the heater and shorting out. so i replaced pump, all ok for a couple of weeks now its started again found more water in the back is there anything im missing ive not done much on this mod b4
    ta paul
    #217096
    Re: white knight t/d
    Demolish the machine; ie drum out. Clean everything…… Check lift pump impellor is still on its shaft.
    comptonappliances
    had this loads on under gtd machines for white knite technical were no help at all .most i came across were up aginst an external wall and condensation was forming in panel to such an extent it would get on fan and splash onto heater.if it the model without collection bottle whereby collect water in a bowl etc if they dont empty straight away the water can suck back and overflow into back panel seen this happen with my own eyes
    #217098
    hilly
    thanks for replies i will double check and clean everything and it is on a outside wall.
    thanks again paul
    #217099
    keithwilliams
    if you remove the heater and complete back panel, you will see the path which the water takes from the condenser into the sump where the pump is.there will be a piece of soggy fluff trapped in the lowest part of the water channel. this allows water to build up and flow over the blocked drain and into the fan housing. as said before, if you’ve stripped it this far you might as well take out the drum and clean the whole thing.
    oh i forgot to mention thet the offending fluff will be found if you remove the section which is held in place by two silver slide clips.
    #217100
    hilly
    thanks for the replies i finally gave in and my friendly local serviceforce engineers took a look with me and it was the timer at fault not running the pump enough!!
    thanks again paul
