white knight t/d
  • #40768
    cornflakes
    looked at yesterday CL43unit
    trip had popped out, re-set and left unit working
    client ran for 4 hours and trip popped out again
    unit is fully intergrated in cupboard run, vented to external wall, louvre opening and flow of air from it appears ok
    any ideas why trip is popping so regular
    thanks
    Graham
    #267473
    Re: white knight t/d
    got to be an airflow problem not much else it can be check to see if the seals are ok this dryer is the vacuum type ie motor sucks air out of drum and the only way air can get in is over the element if door seal missing or drum seals damaged air will get in and bypass element causing overheat
