dryer runs for 20 mins then goes cold,checked filter,condenser and water container, and there are no leaks.reset stat and it will go again no blockages
hi cl767sv standard crosslee condensor drier suffix sv for silver? If motor and fans are ok filters etc, the stat under drum is usually at fault. Bit of a pain to do, back off, drum out.
Yep and dont forgetto tale a spare fan because if its seized then dont pull it you will damage the motor arm and boy do they get noisy.If fan at back stuck crack with screwdriver the cost of a fan is cheaper then a new motor
