White Knight tumble dryer – no heat
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum White Knight tumble dryer – no heat
  • #77390
    T0rNaDo69
    White Knight condenser tumble dryer
    model CL767
    ser. no 0201734780
    the tumble dryer works but no heat..
    ive taken the back panel off to get to the thermostats and heater.
    the heater element looks fine.
    there are two thermostats in the back above the heater element.
    normal one, tested with multimeter on resistance and gives full continuity
    the other one, is a reset one this gives full continuity, when you pull the pin out it cuts off the circuit, but when you let it go, it reconnects the circuit again..
    are there any other thermostats anywhere. ?
    that could be stopping it from heating.
    cheers
    #402066
    Re: White Knight tumble dryer – no heat
    Like lots of things in life, looks aren’t everything. Have you tested the heater for resistance/conminuity?
    #402067
    T0rNaDo69
    hi iadom. yes i did test the element and it was fine.
    #402068
    There appears to be at least six varients of the 767.
    Have a look HERE
    Might give you a better idea.
    #402069
    T0rNaDo69
    ok cheers for the link.
    i will have to take a photo of the machine and see if i can match it with one of those six..
    #402070
    T0rNaDo69
    right i checked the back of the dryer and found the code.
    0312 767 15003/1
    so that puts it in this manual.
    0312_767_15002_15003_&_variants
    im going to test run it without the back cover on to see if the element heats up on both low and high settings.
    as both thermostats test ok ?
    so cant see what else it would be.
    #402071
    Do not run it with the back off.
    #402072
    T0rNaDo69
    i can understand that for saftey reasons.
    though im not likely to touch the spining blower or the hot element.
    well it doesnt matter if you have it on high heat or low heat.
    only one of the eight element springs heat up..
    at a bit of a loss on this..
    could it be the hi and low switch
    is it the element
    or something on a PCB if it has one
