White Knight Tumble Dryer No heat C44AW
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries White Knight Tumble Dryer No heat C44AW
  • #84823
    simon26r
    Anyone know what this is or had this problem.
    Went to a C44AW today with a fault of no Heat.
    Checked everything, Followed circuit all the way round, overload,stats,element could not work it out as my meter said its all working. (checked all cable ends)
    I then decided to move the heating circuit over on the mains terminal block and BANG! only joking I turn on tumble and it worked so guessed maybe timer fault but it tested ok so I moved the heating circuit back over to its correct location and the thing started working . @~@~#’#
    The customer put a load of washing in and it done the first dry without a problem but 2 hours later nothing… no heat again
    HELP! lol
    #426916
    Re: White Knight Tumble Dryer No heat C44AW
    look here for info
    http://www.whiteknightrange.co.uk/white … ad-SM.html
    Grendal
    It will be the timer ,done loads of them for that fault
    #426918
    simon26r
    Thank you for that. I did guess it could only be the timer with burnt inner connections. Will keep u posted when fitted.
