White Knight Tumble Dryer Vented
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries White Knight Tumble Dryer Vented
  • #95557
    delta01
    Hi Just had a stuggle with this one 44aw no heat / motor action checked everthing could not work out what the problem was but srongly suspected the timer , However eventually i turned the timer dial on with a litte upward then downward pressure and it came on momentarily .so in future i will try that first . by the way timer id can be challenging on these . hope it saves someone a lot of hassle
    thanks John
    #460736
    White Knight parts ID is usually very good if you follow this link and use the full 0312 *** ***** code John.
    http://www.whiteknightrange.co.uk/service-manuals/
    As you can see there are 39 varients of the 44A model.
