Our White Knight wk767 tumble dryer started getting seriously loud.
Just taken off the back and the bearing is shot.
However looking at it, it would appear to be enclose in a part that is not removable from the drum.
Is this correct or am I missing something?
The three legged support is riveted to the back of the drum and is not available as a spare part. Curiously enough, it is this component working loose which normally makes all the noise………
There is a repair kit for the rest of it, comprising shaft, bush, wiper and screw. P/no 421309205591 – an email to spares@ukwhitegoods.co.uk if you wish one supplying.
Just worked out how to get it off….not a bearing system.
The three legged support is solid.
There is some movement with the bush on the shaft. should this be a really snug fit?
Also found the fan down the bottom wo be really loose too.
