white knight wk79 condenser dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries white knight wk79 condenser dryer
  • #20445
    phil59
    ok guys i know someone has come up against this before so ***””!*@
    help please white knight co dryer wk797 when it runs clock wise its ok
    when it runs anti clock wise it trips the house fuse box ???
    ive run it for hours with a surge protector on it and its fine ???
    cheer in advance phil
    #187101
    wilf
    Re: white knight wk79 condenser dryer
    I had similar on one of these caused by condensation forming on the heater. machine was running backwards causing reverse airflow. if I remember right ,it should run clockwise main sequence short run no heat reverse (anti tangle). timer was faulty.
    ring croslee their very helpfull……………….but…………..worked fine in the shop (two loads)…………….back at customers tripped again and I could see the condensation on the heater I spent ages on this and was thankfull that she decided to replace it
    lost out but well thats life sometimes. Id like to know how you make out. hope this helps.
    wilf
    #187102
    phil59
    cheers wilf ill take a look at timer phil
    #187103
    phil59
    you wont belive this?????? yes you will.when it was manufactured they fastened the back down on one of the wires and put a screw all the way through it so when it went anti clock wise it triped. so there you go the **@@!!*|ds
    thanks for lookin hehe
