Model CL447 The blower fan is adrift, not stripped right down, just felt into vent.
Entered the code in SIOS and it came up with what appears to be correct part, Fan 481951528127. Is it likely to be just a fan failure or are there any fixings required, also how difficult a job is this to change?
Easy peasy – lower rear cover off, undo motor bracket from underneath, pull pin from fan chamber cover and twist it, the whole lot pulls out backwards.
Cheers Chris, I may have made a mistake but I’m sure the dryer I saw had model number CL447VW, yet the Whirlpool one that comes up on SIOS is CL447WV, 😕
