White Sneakers in Washing Machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum White Sneakers in Washing Machine
  • #31295
    WhiteGd
    Can I ask if I put my white sneakers into my washing machine, will it wreck my washing machine? The washing machine has rubber barriers things.
    If it is safe, what should I do to protect the washing machine drum? What settings should I use?
    #230569
    Front or top loader?
    Plastic paddles or metal (part of the drum)?
    Generally speaking, trainers or sneakers if you hold a US passport (;)) in the washer is usually a bad idea.
    WhiteGd
    Re: White Sneakers in Washing Machine
    thanks for your post kwatt!
    yes washing machine is a front loader and the paddles are plastic
    ok..understood…i just heard people putting their sneakers in the washing machine…they said you just need to put it into a bag (e.g. pillow) so it doesn’t ruin the drum
    but before I do that, I thought I would check first!
    #230571
    Nope a bag won’t stop damage, trust me, I know this. 😉
    Kleeneze and possibly Bettaware and Lakeland do sell trainer washing bags. I have just had a look on the Kleeneze site, it appears to be a mesh bag with foam paddings. I suppose that if you did use one of them and it damaged your machine you could sue Kleeneze. 😉
    Only £6.00
    WhiteGd
    thanks guys! i don’t think i will risk it! thanks again!
