White-Westinghouse Fan Oven won’t heat
Home Forums Public Support Forums Help And Support Cooker And Oven Forum White-Westinghouse Fan Oven won’t heat
  • #9351
    Hello,
    I’ve got a White-Westinghouse Fan Oven (model number 05-200301) which won’t heat. The fan works okay as does the grill.
    I’ve tried calling Caremark but just found out that the guarantee is now worthless. Is is worth calling them to pay for someone outside of warranty or is this a job I could do myself (with the right parts)?
    I’m based in North-West London NW6.
    Thanks.
    #133651
    Re: White-Westinghouse Fan Oven won’t heat
    I have Model no. 05-200306 and the same problem the fan works but the oven won’t heat, i can’t find anyone in the area who can deal if you have any luck please let me know.
    #133652
    The elements (99.99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} chance that’s what the fault is) is readily available. If you email Dave on spares@ukwhitegoods.co.uk he’ll sort it out for you.
    Dave_Conway
    OK Wilmott needs ELE2040 from the shop, Simon needs ELE2015
    http://www.ukwhitegoods.co.uk/modules.p … Path=26_52
    No need to email 😉
    If you need an engineer to fit, try repairs@ and the directories, if you are having a go yourslef, please pull the plug :zap:
    #133654
    Order placed.
    Many thanks – that’s great!
    #133655
    Barnesey
    Hi, I have exactly the same problem as Simon had. However, my model number is (according to the front of the owners guide) 200301. No 05 prefix. Is this the same model?
    Many thanks.
    #133656
    Dave_Conway
    Yes, it’s the same oven Barnesey. The prefix denotes the colour option 🙂
    #133657
    Barnesey
    Thanks very miuch!
    #133658
    Dalboyne
    Hi there. In my case it’s a hite-Westinghouse Stainless Steel Oven: 05-203105. For a while it was cutting out when it got hot, then it would have to cool down before it would work again. But now it won’t start at all.
    I’d be very grateful for advice. Its about 7 years old, but buying a new oven isn’t an option. The flat is in London – E14 9QZ.
    Thanks for any help
    Ian
    #133659
    Dalboyne
    Sorry – forgot to ask – is this a simple fix job for a layman? Or do I need an engineeer call-out?
    Cheers, thanks again
    Ian
    #133660
    Dave_Conway
    Dalboyne wrote:Sorry – forgot to ask – is this a simple fix job for a layman? Or do I need an engineeer call-out?
    203105 is a Smeg manufactured oven
    Ensure that ventillation is good as restricted air folw can cause this.
    Apart from that, I would recommend an engineer to be honest for a fault like this, check the repairs@ link below, that should provide someone 🙂
    #133661
    Dalboyne
    Thanks for the advice Dave
    Am using your repairs@ link to try to find someone to fix
    Ian
    #133662
    Eastoak
    Hi, just looking around for options. I also have a White Westinghouse oven (model 02-203101) and the only element working at present is the top one, the bottom one, the grill and the fan elements don’t work. The analogue clock hasn’t worked for years. I’ve taken the oven out of its housing and tried to get at the elements but it looks like a major dismantling job and I’m just about ready to bin the whole thing. It was bought in 1999 which isn’t that long ago but I wonder if it would be more cost effective to buy a new one. Problem is I like the style and all the current models are boring and square. What would you suggest? I guess the new parts would set me back £100+ including new gaskets.
    Thanks, Rich.
