Home › Forums › Public Support Forums › Buying Advice › White-Westinghouse Fridge Freezer Replacement Width 71 cm
- This topic has 4 replies, 3 voices, and was last updated 14 years, 10 months ago by
JM_2.
May 26, 2011 at 1:32 pm #63021
JM_2
ParticipantHi,
May need to replace my White-Westinghouse Fridge Freezer. Model RTD16VJ. Frost free.
External Dimensions
Wide 71cm 28 inches
Height 160 cm 63 inches
Depth ; 61 cm 24 inches ( without the grill ).
Freezer : W 71 cm x H 43cm x D 61 cm
Fridge : W 71 cm x H 107 cm x D 61 cmInternal dimensions :
Freezer : W 63 cm x H 36 cm x D 50 cm
fridge : W 63 cm x H 102 cm x D 50 cm
Done a web search. Did not see White-Westinghouse fridges around in UK.This one seems similar to mine :
Model WWTR1502KW
http://www.whitewestinghouse.com/produc … 1502KW.asp
Can one get these in UK
Which other fridge freezers of equivalent size are reliable and best.Are there any around that are 71cm wide ( 28 inches ) .
Some quote in litre capacity. Not sure how they work that out.
Looking for Fridge and Freezer of same proportion. Or larger fridge section would be OK.
Must not be wider than 71cm External. Prefer this wide.
Existing one is right hinged, which we prefer.
JM_2
May 26, 2011 at 2:33 pm #352219don
ModeratorRe: White-Westinghouse Fridge Freezer Replacement Width 71 c
Hi jm_2
70cm wide refrigeration is a niche area that hardly any manufavturers cover. Having a quick Google I found a Smeg which is a similar size to your WW. You may need to phone the supplier as it is showing as out of stock.
The only other decent one I can find ia a Siemens KG49NH90GB but that has a bottom mount freezer.
Refrigeration capacities these days are always quoted in litres, to convert simply divide the litres by 28.31 to arrive at cubic feet.
HTH 🙂
Don
May 26, 2011 at 3:44 pm #352220JM_2
ParticipantRe: White-Westinghouse Fridge Freezer Replacement Width 71 c
Hi Don,
Thanks for the quick reply.
Smegs looks the right size. It’s bit pricey I think.
I have a Smeg hob and the ignition lighter went within a short time.
The Siemens looks pretty good. Not sure if the capacity is similar to my old one. I don’t mind if the freezer compartment is lower.
I have had a go at working out internal cu. ft. ltr on my White-Westinghouse
Freezer is 4.05 cu ft = 115 ltr
Fridge is 11.57 cu ft = 327 ltr
Total is 15.62 cu ft + 442 ltr
Hope I have got that right.
May be cheaper to go for a 60cm wide as long as the capacity works out similar to the old. Suppose it would work out very tall , if they are around. Would need a ladder lol
JM_2May 26, 2011 at 4:49 pm #352221admin
KeymasterRe: White-Westinghouse Fridge Freezer Replacement Width 71 c
The Smeg will actually be a Gorenje appliance badged for Smeg. Personally
your own appliance which is a original GE which is a true american appliance and a reliable one.Repair it.Bryan
May 26, 2011 at 5:19 pm #352222JM_2
Hi Bryan,
I have really been pleased with my White-Westinghouse.
Not sure how much it will be to repair ? Any ideas ?
Also, whether the parts are available ?
JM_2
