Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › WhiteKnight 767c – drum won’t turn
- This topic has 5 replies, 4 voices, and was last updated 16 years, 9 months ago by
JenJam.
July 11, 2009 at 2:34 pm #46976
JenJam
ParticipantI have a WhiteKnight Condenser 767c tumble dryer. The drum won’t turn. I took off the top of the machine and checked the belt – it is tight to the drum. The drum would turn but felt as if it was off centre, like it had fallen out of its holding.
I pulled off the back of the machine (VERY gently) and have spotted what I believe the problem may be. I’ll do my best to describe it fully, it’s impossible to get a good picture.
There is some kind of clamp which seems to hold the drum to the back panel. This clamp is located in the centre of the circle which makes up the back of the drum. It’s broken, with an irregular tear which to me means something hasn’t just popped out. This matches up with the way the drum could be turned by hand earlier but felt off centre.
OK, it certainly doesn’t look like a repair I can do myself. But my question is to ask if it’s worth getting someone in to repair this and roughly how much the part is, or is it a case of a new machine?[/img]
July 11, 2009 at 2:38 pm #291827helo_75
ParticipantJuly 11, 2009 at 2:56 pm #291828JenJam
ParticipantRe: WhiteKnight 767c – drum won’t turn
thank you for the quick reply … not sure if this is what i need, the “clamp” is on the drum itself … photos are here:
http://s328.photobucket.com/albums/l346/JennyFarSpacedOut/dryer/July 11, 2009 at 5:57 pm #291829Penguin45
The drum “spider” has disintegrated – it isn’t a spare, so the replacement part is a new drum assembly – likely to be £70-80 plus.
I have to say that looking at the state of the spider, it must have been noisy for some time………
July 11, 2009 at 6:40 pm #291830JenJam
Ah, I had a feeling it might be the drum needing replacing, and not a job I’d like to take on myself.
Thank you very much for the replies, it’s reassuring to have some impartial advice. I’ll do some sums about getting a repair done, but it may be a case of replacement. And yes the machine had been noisy but not much more than it had been when we first got it. Seems I’d better pay a bit more attention. You live, you learn.
thank you again for the replises – much appreciated.
July 14, 2009 at 1:47 am #291831gandh1
The repair is gonna be about £140 – £170 depending on the exact drum type you have, which is new machine territory.
I seem to take out 1-2 white knights a month tho, so I can keep an eye out for one with a ok s/h drum if you would like?
