Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › WHP / Proline TDC75 (8540 635 15001) T/dryer stats.
- This topic has 7 replies, 2 voices, and was last updated 17 years, 4 months ago by
leavemetogetonwithit.
November 13, 2008 at 10:44 am #41005
ParticipantThe two stats that fix on the heater with a clip. Have got 4812 259 28681 as replacement from Masterpart. Just wondering … old ones were identical; no colour markings and same number on contact surface (A260).
New stats have one plain (A260) and one green (A210).
I’m thinking they must have fitted it wrong when manufactured.
Does it matter which one should go to top?
Appreciate any help.
Mike.November 13, 2008 at 11:10 am #268331bzz67
ParticipantRe: WHP / Proline TDC75 (8540 635 15001) T/dryer stats.
usually the tags have coloured sleeves, the green tags to green spot stat.
November 13, 2008 at 11:42 am #268332leavemetogetonwithit
Thanks bzz. However the ones on this machine had all tag insulators coloured black 🙁 .
I noticed that the lower stat was connected in line with a heater terminal so I think that would be the safety stat. But which one should that be, green or plain?
Mike.November 13, 2008 at 12:04 pm #268333bzz67
Safety thermostat
(in heater) TLSwitch on temperature
<-35 °Cmin.
< °Cmax.
35 °CSwitch off temperature
260 ± 10 °CFluff thermostat
Color codeGreen
165 ± 10 °CSwitch off temperature
210 ± 9 °CExhausting thermostat (in airchannel) TH 1.1
TH 1.1Switch on temperature
68 ± 3 °CSwitch off temperature
83 ± 3 °C
this is from whirlpool, it appears the green spot is the operating stat and the other being the higher temp tocNovember 13, 2008 at 12:44 pm #268334leavemetogetonwithit
Many thanks bzz, that’s really all I needed to know. I’ll put the plain one directly in line.
I did think it a bit unusual that both stats had gone o/c.
I guess that it must have been cycling on the exhaust stat until now.
Perhaps I’d better order up one of those too as it’ll probably be pretty burnt out. Presumably the two safety stats had to fail in turn on the one overheat occasion.
Mike.November 13, 2008 at 12:50 pm #268335bzz67
i see they call it a fluff thermostat, it probably only operates when a blockage in filter reduces the airflow so that the exhaust stat does’nt really get the heat.
November 13, 2008 at 12:54 pm #268336leavemetogetonwithit
Thanks for good info. I’ll give it all a clean out.
Mike.November 15, 2008 at 12:04 am #268337leavemetogetonwithit
Went back here today. Turned out there was a green paint spot on one of the insulators and white spots on the other three. Didn’t note that first time round 😳 . So I fitted them accordingly. All OK now. Asked customer a few Q’s. She said it did used to get very hot (surprise, surprise) and she was always opening the door before the prog. finished and taking the clothes out steaming hot! :rolls:
Thanks again bzz.
Mike -
